7 members (gmcn, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff, sprinty), 258 guests, and 77 robots.
Sagging Hood
Topics49,858
Posts837,463
Page 10 of 20 1 2 8 9 10 11 12 19 20
Jay - you are very brave. shocked2
Steve, I have a similar issue on the bonnet and around the top of the wings of my red 4/4. I wondered if it was connected to the autoglym hi def wax I used - as the first circles appeared after I treated it to some a year or so ago.
Last year I had the car detailed which improved it a lot, but the chap who did it was reticent to get too aggressive with the cutting compound on 24 year old paint.
I think I need to let him have another go, I had been wondering about clay, as I was able to restore the blackness back to our jeep last summer
Jays. For dealing with stone chips you need a dozen pencils with rubbers on the end, 3 grades of fine wet and dry, a hole puncher for putting A4 into a ring binder/ leather punch, some evostik plus paint, thinners, fine artists brushes, autoglym polish or similar and a 40w inspection lamp. I usually buy the paint from Halfords, spray cans give a better result than touch up sticks, look around the carparks for cars that are a good match to your Morgan then buy the appropriate colour.
Punch some circles of wet and dry and glue to rubbers on your pencils. This will allow you to flatten the paint between coats without colateral damage, just rotate the pencil between thumb and fingers applying light pressure. Use the inspection lamp to bake the paint between coats and when satisfied finish off with the autoglym. On non metallic paints it is possible to achieve a near invisible repair.
Great tip Easter.
I use Easter's method except I use a hair dryer (low speed) instead of an inspection lamp.
I was always taught to use lots of water when rubbing down between coats.
Bud
budster
Bud
4/4 "Stanley"
Being a bit of Jay Leno fan I happened upon this video advocating the steam cleaning of cars, outside, inside and under the bonnet.
Surely this can't be right.
http://www.youtube.com/watch?v=5bXmxRjjAw8
2015 Plus 4 (GDI) Sport Green
I beleive that steam cleaning wash all the rage 20 years ago, the engine bay and suspension being given a thorough claer. It was then found that the steam cleaning was removing oil and grease from areas that need protection. Chrome wire wheel were also a problem, as the steam could be forced between the spokes.
This stuff is excellent for cleaning leather - used a leather wipe in the re sealable packets - little effect so got this from the Wife's cleaning cupboard and it lifts the grime off a treat.
Used a leather wipe to apply it and a clean leather wipe afterwards to remove any residue.
Called White Wizard - it is waxy stuff - wife says it came out of a catalogue years ago. Made by LB Roe California.
2016 Carmine Red 991.2 C4S
That's great and systematic way to wash a car.!
