7 members (James B W, 2949olivier, Graham, G4FUJ, sprinty, MartO, Jens, gaston), 309 guests, and 38 robots.
+8Rich 92
Posts837,279
Originally Posted By AJSki2fly
So the test to be done is to put my tyres from Rosie onto my friends car and see if it then drives the same. I will report on our findings in the near future.
Adrian, I'm really interested in the shimmy issue and wonder if you have had the time to try your wheels on your friends car yet? I think a result from such a test will be very valuable.
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Lecat #150511 19/08/13 06:54 PM
I spoke with both Adrian and Graham on Friday when they popped round with both +8s and the tyres swapped. It would appear that the Adrian's tyres were far superior and proved that Graham's 10+ year old tyres were in need of replacement. Although they look ok, it seems that the tyres harden out and can cause steering and road holding problems. The shimmy had disappeared.
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
NeilM #150524 19/08/13 08:15 PM
My friend who had a '99 4/4 with the original tyres has just fitted new tyres. He can't believe the difference and is really glad I talked him into it. I can't believe he made them last over 13 years scared
NeilM #150766 21/08/13 09:39 AM
Neil
I think the result shows that tyres (and/or wheels) can be the cause - it did in my case. I can also imagine that certain types could generate a greater effect than others.
Even if perhaps a bit premature, I think there is a pattern emerging: The shimmy itself is not caused by imperfections in the construction but by imperfections in tyres and rims (as well as all other parts involved). On the other hand I believe that the delicate lightweight construction is more sensitive to uneven or unbalanced tyres/wheels than modern car's.
For this reason I have fitted a steering damper and will also fit 'brake reaction bars' - even though my shimmy is completely gone since I fitted two new rims in front.
