6 members (jejemek, Graham, G4FUJ, Montegue, Pittsartist, Image, James B W), 212 guests, and 64 robots.
+8Rich 94
Posts837,271
Page 3 of 3 1 2 3
donaldosaurus #148238 07/08/13 05:01 PM
One great looking car!
Richard - Aus #148257 07/08/13 06:11 PM
Open Photobucket in a seperate tab and navigate to the desired image.
For Firefox, right click on the image and 'copy image location'.
Internet Explorer is not your friend as it is more complicated. Again right click on the image, and at the bottom of a long list, some of which is greyed out, select 'Properties'. A little pop up then appears and select all of the address and hit the control key and the 'C' key together. This does the same thing as the Firefox command and pastes it into your clipboard.
Then select the Talkmog tag and write your post.
In the 'Posting form', hit the fourth button. They go 'Smileys', 'Webpage links', 'Email links' 'Enter an image'.
Press the 'Enter an Image' button and from the top, select 'Insert a non-floating image' (you can play around with the others when you've got this bit right!). Then you get a screen that says, 'Enter the complete URL for the image you wish to display'. Then press the Control key and the V key together and this pastes in the contents of your clipboard.
Doing this with donaldosaurus's latest image should give the picture, like this:
If you preview you get the image so you can check, and if I swap the square brackets for squiggly ones, you should see that the image must end in dotjpg and the exact form the button and process should give.
{img}http://i448.photobucket.com/albums/qq205/talkmorgan/IMG_1939_zps76757c91.jpg{/img}
I'm not a geek, honest...
Last edited by Martyn Culling; 07/08/13 06:16 PM. Reason: bit of correction - ow...
Richard - Aus #148278 07/08/13 07:45 PM
It's a very mean looking car! The first I've seen all in black.
Jays #148328 08/08/13 08:35 AM
That is SMART! thumbs
Jays #148334 08/08/13 09:07 AM
Maybe needs the exhaust shields black too?
donaldosaurus #148360 08/08/13 12:08 PM
"Maybe needs the exhaust shields black too?"
No, I think you have it spot on, the polished alloy heat shields and ss pipes pick up the brightwork on the front of the car perfectly.
PaulJ #148371 08/08/13 01:21 PM
I also agree, it looks nice as it is. It's not, by any means, a stealth motor, so why try to make it look like one?
The polished bits set off the black nicely. Is it a plain black, or a metallic/micatalic finish.
Martyn Culling #148373 08/08/13 01:41 PM
I see what you mean about not being a stealth car and maybe the contrast is good. I now have silver roundels and black numbers on it for a bit of fun.
Just a plain flat black, it looks great in all lights. When I bought it, it was in a showroom next to a silver and a red car and it really stood out, well to my wife and I anyway. So much so that she just said if you want it buy it. Never look a gift horse in the mouth!
donaldosaurus #155024 12/09/13 08:42 PM
Hi Donald, I too display my tax disc in the same place as yours and you are right, you must display a current tax disc.
I once got done by DVLA £330 for failing to display a tax disc, plod were not bothered as all documentation was present and correct, tax disc was in the post from DVLA.
No amount of ranting and letter writing would sway them though, pay up or we'll take you to court at your expense.
Heads they win tails you loose.
Jays #155029 12/09/13 10:04 PM
+1
Page 3 of 3 1 2 3
