0 members (),
270
87
Topics49,869
Posts837,666
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
As mentioned previously mine is Zircotec coated and has not caused a problem for me (It doesn't seem to be as close to the water feed as yours though.. Perhaps This from Autospecialists would be a 'prettier' solution.. Stainless Steel Exhaust heat shield
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 1,502 |
Thanks Keith - actually your installation looks exactly the same as mine, I don't think there is any difference in the spacing. I will check with Burton Power what the stud spacing and other dimensions are on that heat shield, as it is designed for a CVH. However it is a great idea, and it looks as if it would be relatively easy to make one in aluminium backed with heat shield mat, to fix onto the manifold studs.
I see you have braided return hoses from the rad to the expansion tank!
GLLHG - will look at that too.
Does anyone know (or could measure, please), the manifold stud spacing of the CVH as compared to the Zetec (black top)?
Thanks
Posts: 1,502 |
Posts: 2,190 |
GLLHG
Posts: 1,502 |
Thanks G, are you able to post a photo of your heat shield in situ, so I can see which one? That would really help. Actually which engine do you have? Nigel
Posts: 2,190 |
Nigel, I've PM'd you regards G
GLLHG
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
I'm late to this but when replacing my rad with a Mulfab it did indeed drop out (with a bit of a wiggle). I do have to keep tightening the circlips to the top hose though to deal with a slight leak.
I know someone who fitted a mulfab rad and he fitted a pair of clips...why can they leak??
Keith
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Different co-efficient of expansion compared to a standard rad?
But a hose connection is a hose connection or am I missing something?
Keith
