1 members (+8Rich), 308 guests, and 97 robots.
+8Rich 76
Topics49,869
Posts837,666
Moggo
Page 3 of 7 1 2 3 4 5 6 7
As mentioned previously mine is Zircotec coated and has not caused a problem for me (It doesn't seem to be as close to the water feed as yours though..
Perhaps
This from Autospecialists would be a 'prettier' solution.. Stainless Steel Exhaust heat shield
Keith
Thanks Keith - actually your installation looks exactly the same as mine, I don't think there is any difference in the spacing. I will check with Burton Power what the stud spacing and other dimensions are on that heat shield, as it is designed for a CVH. However it is a great idea, and it looks as if it would be relatively easy to make one in aluminium backed with heat shield mat, to fix onto the manifold studs.
I see you have braided return hoses from the rad to the expansion tank!
GLLHG - will look at that too.
Does anyone know (or could measure, please), the manifold stud spacing of the CVH as compared to the Zetec (black top)?
Thanks
Actually this one looks like it might fit straight on - http://www.burtonpower.com/manifold-heat-shield-escort-zetec-mk5-mk6-sscmhs1.html
South Wales Correspondent
Looks familiar. I went for the stainless steel one
http://www.burtonpower.com/catalogue-2013/cat-2013-page-65.html
I did the same trick with the braided hoses
I also fitted a stainless steel cam belt timing cover:
http://www.burtonpower.com/parts-by-category/engine-components/stainless-steel-components.html?p=2
GLLHG
Thanks G, are you able to post a photo of your heat shield in situ, so I can see which one? That would really help. Actually which engine do you have?
Nigel
Nigel, I've PM'd you
regards
GLLHG
I'm late to this but when replacing my rad with a Mulfab it did indeed drop out (with a bit of a wiggle). I do have to keep tightening the circlips to the top hose though to deal with a slight leak.
I know someone who fitted a mulfab rad and he fitted a pair of clips...why can they leak??
Keith
Different co-efficient of expansion compared to a standard rad?
But a hose connection is a hose connection or am I missing something?
Keith
