Morgan Aero 8
2 members (DaveK, +8Rich), 386 guests, and 24 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,085
#150751 21/08/13 07:41 AM
sospan Offline OP
A mate,s aero8 has an annoying problem.
When cold it starts as normal. When there is some heat-even after a very short drive- it stalls when on tick over at junctions etc. It's then slightly sluggish to fire up again.
This started after a " spirited run".
All easy to get at hoses/connections look ok.
My FCR does not work with it so a bit of a head scratcher.
It could be any one of a number of things but it has to be temperature related in some way as the car starts and runs ok from cold.
As an aside, is the ecu/map a standard BMW or a bespoke Morgan version?
This would determine where the car could be checked as nearest dealer is some distance away.
Initial thoughts are a MAF/throttle/coolant sensor issue?
BUT it could ultimately be anything.
confused2
Had this on my S1 - Air Mass Sensor failure
New joints for old!
sospan Offline OP
Thanks orthodoc.
I am sure my mate has seen this already!
We thought it might be the cause.
He only has to locate it now!!!!
sospan Offline OP
I think it's in the air supply duct to the manifold at front end of engine.
