Morgan Aero 8
8 members (JohnHarris, RichardV6, DickJ, TBM, Tresco, Rudolf, Strathaven, Grumpy2), 198 guests, and 74 robots.
+8Rich 73
DaveW 52
Topics49,867
Posts837,619
Moggo
Page 6 of 72 1 2 4 5 6 7 8 71 72
Ale_72 Offline OP
If you want a thing done well, do it yourself laugh
So... For you probably it's already old story, for me it was interesting. A lot interesting.
Oil sump 1
oil sump 2
Air filter tube
Transmission
Exhaust
Exhaust 2
Exhaust 3
LSD and exhaust
LSD
Always interesting to see photos - thanks for sharing.
+1, clear lines underneath.
Ian
Ale_72 Offline OP
Originally Posted By Simon
Photos sent you via email smile
Grazie Simon wink
My expectation was to see in metal the accelerator pedal and in rubber the brake one.
Ale_72 Offline OP
Hi all,
I need your help again.
Could anybody take a picture of the side/rear of the brake pedal?
I have now removed the block on the accelerator but I have the feeling that some modification was done on the brake pedal as well (since the brake pedal is MUCH higher than the accelerator. Yes, I know that it's normal that they have different heights but this one is far too much)
Before I touch that I wanted to make sure to operate in the right way.
This is the as is:
I know we have different designs of cars but I had a similar issue and it turned out to the be the rubber grommet on the engine bay side of the pedal rod...it had worn out. Replaced and all was good.
Ale_72 Offline OP
No, it's not only a rubber grommet. It's much more relevant.
And if you look at the first pic of Simon, it seems to me that he does not have this "extension".
I can confirm that Ale_72's pedal isn't "normal" - having driven the "Other" SS on Saturday.
If I had known I would have taken a photo for you.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
Ale_72 Offline OP
As I told you, I discovered it on Tue frown but I appreciate your offer. If nobody finds a picture, I'll have to wait that you buy yours! smile
Waiting for somebody with some goodwill of taking one smile
le Asbo du Bling
le Asbo du Bling
Ale,
Wasn't it your car that has the piece of wood attached to the accelerator.
This might have been a good mod for short person wink
Slowly going green
