10 members (Graham, G4FUJ, CooperMan, Morganmike, DaveW, MJF, Mike D, PaulV, +8Rich, Moggo, sprinty),
274
149
Topics49,869
Posts837,658
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
If you want a thing done well, do it yourself  So... For you probably it's already old story, for me it was interesting. A lot interesting. Oil sump 1  oil sump 2  Air filter tube  Transmission  Exhaust  Exhaust 2  Exhaust 3  LSD and exhaust  LSD
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Always interesting to see photos - thanks for sharing.
Richard 1976 4/4 4 Seater
Posts: 3,643 |
+1, clear lines underneath.
Photos sent you via email Grazie Simon    My expectation was to see in metal the accelerator pedal and in rubber the brake one.
Hi all, I need your help again. Could anybody take a picture of the side/rear of the brake pedal? I have now removed the block on the accelerator but I have the feeling that some modification was done on the brake pedal as well (since the brake pedal is MUCH higher than the accelerator. Yes, I know that it's normal that they have different heights but this one is far too much) Before I touch that I wanted to make sure to operate in the right way. This is the as is:
I know we have different designs of cars but I had a similar issue and it turned out to the be the rubber grommet on the engine bay side of the pedal rod...it had worn out. Replaced and all was good.
No, it's not only a rubber grommet. It's much more relevant. And if you look at the first pic of Simon, it seems to me that he does not have this "extension".
Posts: 861 |
I can confirm that Ale_72's pedal isn't "normal" - having driven the "Other" SS on Saturday.
If I had known I would have taken a photo for you.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
As I told you, I discovered it on Tue  but I appreciate your offer. If nobody finds a picture, I'll have to wait that you buy yours! Waiting for somebody with some goodwill of taking one
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Ale, Wasn't it your car that has the piece of wood attached to the accelerator. This might have been a good mod for short person
Slowly going green
