3 members (yrr13, Alan Patterson, Chris Cosher), 296 guests, and 27 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
#151269 23/08/13 09:25 AM
We're about to go touring in LB, but the luggage on the rack obscures the central brake light...is this legal, or do I need to fit an auxilliary light?
Thanks
Mike
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Not absolutely sure, but I think that if the light is fitted it must work and be visible. Quick fix might be to remove it altogether. Gerry.
Gerry
Yes that is correct.
So either remove it if you can, or arrange some form of alternative light, which I know others have done.
Mike, I drove all through France, Italy, Swizerland and Luxemburg in both of my Moggies without the Cyclops brake light and had no problems at all.
I worked on the basis that if it's not there then it can't be expected to work!!!
Have a good time
Reg
Reg
I didn't lock my front door, nor did I get burgled; I'm of the view it's better there than not.
Bum! Thanks for all the advice, I'll see what I can put together...
Mike
You can get LED brake light bars from Halfords. (Made by Ring - £19.99)
This can be mounted onto a strip of plastic/wood/ali which you can they fix under the luggage straps that hold your case to the rack.
Run a connector extension from the cyclops light, which can then be plugged in, as requird.
Bud
Bud
4/4 "Stanley"
