9 members (vincentvg, Zach, RichardV6, TBM, Mike D, RedThree, paulmog, John V6, James B W),
273
40
Posts837,999
Posts: 157 |
We're about to go touring in LB, but the luggage on the rack obscures the central brake light...is this legal, or do I need to fit an auxilliary light?
Thanks Mike
2011 +4 'LB' Indigo Blue, Heron trim Saab 9-3 1.8T Sportwagon
Posts: 2,814 |
Not absolutely sure, but I think that if the light is fitted it must work and be visible. Quick fix might be to remove it altogether. Gerry.
Gerry
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Not absolutely sure, but I think that if the light is fitted it must work and be visible. Quick fix might be to remove it altogether. Gerry. Yes that is correct. So either remove it if you can, or arrange some form of alternative light, which I know others have done.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Mike, I drove all through France, Italy, Swizerland and Luxemburg in both of my Moggies without the Cyclops brake light and had no problems at all. I worked on the basis that if it's not there then it can't be expected to work!!! Have a good time
Reg
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I didn't lock my front door, nor did I get burgled; I'm of the view it's better there than not.
Richard 1976 4/4 4 Seater
Posts: 157 |
Bum! Thanks for all the advice, I'll see what I can put together...
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Mike You can get LED brake light bars from Halfords. (Made by Ring - £19.99) This can be mounted onto a strip of plastic/wood/ali which you can they fix under the luggage straps that hold your case to the rack. Run a connector extension from the cyclops light, which can then be plugged in, as requird.
Bud
Bud 4/4 "Stanley"
