6 members (tommog, MATTMOG, John Winn, +8Rich, Jon G4LJW, nick w), 325 guests, and 45 robots.
John V6 71
DaveW 67
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,991
RedThree
Just looked under my dash. There is a dangling socket but a lot smaller than the socket on my 2010 4/4. Could it have an ODB1 rather than OBD2 socket?
Also, looking in the fusebox under the bonnet, there is this strange box of tricks! Any idea what it is for?
It's a mini Interocitor evil
David,
In 2009 my friends MK2 Roadster a 2008 had the error code for low fuel pressure on one of the banks. Within a month the factory had to fit a new engine due to damage caused by this issue. It was not a one off there were other cars with similar outcomes.
Dave
My plus8 light came on last year.
Connected an Autel unit to it and it showed
"Intermittent misfire".
I reset it.
Checked plugs/leads
It came back once but not since
Your OBD plug will be near the steering column as they have to be positioned within a certain distance of the column.
OBDII is 16 pin plug
My 4/4 CVH had a Ford 3-pin type
If that device isn't an Interociter it could be a Warp Drive interface...?
Peter J Offline OP
Formerly known as Aldermog
Jay, my Morgan doesn't have that strangerounded end box....perhaps "they" are tracking you!
The OBD socket is under the dash, about central and has 16 sockets, but a good few have no input wire....!
More once I've had it hooked up.
Peter J Offline OP
Turns out it is a" below range reading" from Lambda sensor No 1 Right.
So nothing of any consequence and my pal with the OBD Computer re-set the syatem. He suggested, and Mike at Williams agrees that it is better to ignore it for now. If it happens regularly then might be worth investigating further.
It would seem that the 3L Roadsters are rather prone to this error.
I had endless problems with the lambda sensors on my 4/4 Sport after fitting my Librands exhaust. I ended up keeping an OBD2 reader in the car to set it!
I'm tempted to do something with the exhaust on the Roadster but don't want to start up problems with the lambdas or make it too noisy. A nice deep burble would be just right!
Didn't the problem go away when you fitted the TBs and Omex?
