Morgan Aero 8
11 members (JMcL, Rovert, Hamwich, DavidR, 42w203, Ruut Bianchi, High Hamster, mph, John V6, Ian Wegg, Camelot), 354 guests, and 28 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,405
Members9,215
Rbt Aero8, Salmon, stevends
Andrewr Offline OP
I have a potential issue with my indicators.
I thought that when I indicated left, they didn't cancel.
Upon further investigation they do self cancel as long as the steering wheel turns through 270 degrees. I checked the right turn and that cancels after 180 degrees.
The car has a Motalita steering wheel and boss.
Is this normal or is there something a miss.
I'm fed up forgetting to turn the indicator off manually, presumably because the corner wasn't sharp enough.
Thanks in advance for any help.
Andrew
Andrew,
Mine are the same with inconsistant cancelling on my S1, also with a Motalita and boss. Although the beep warning does help. With just 30k mileage it isn't because the cars are old, just must be a poor system. It may well be a part that can be obtained from a dealer, perhaps even an upgrade found on later models.
Dave
There is a lobe on the steering column that you can adjust by loosing a recessed grub screw with an Allen key. It should point to either 3 or 9 o'clock depending on with side your indicators are. May need moving up or down the column?
Andrewr Offline OP
I have now fixed this issue.
It turned out the the plastic BMW stator plat was engaged with the steering boss 180 degrees out, also the steering wheel was mounted on the boss one home anti clockwise out. Corrected both issues and the indicators now cancel like on a proper car.
Thought I would feedback I case someone else has the same issues.
Regards
Andrew
Great to hear you're all fixed up.
The indicators on my Roadster don't cancel properly - I bought something called an 'audicator' (a replacement relay that makes a noise) but I'm told it won't fit on the Roadster as it doesn't use a conventional relay.
I'm often being flashed by other drivers as the indicator will be on.
+8 4.8
My understanding of the 'audicator' is that it is not linked to a relay....
