Topics49,849
Posts837,410
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Finally found time to investigate this and it turns out that the gasket was kinked. This in itself wouldn't necessarily be a problem but it had also developed a hairline split - presumably because it was under tension.    To my knowledge, the rocker cover hasn't been disturbed since new so I guess it was sloppy assembly at the S&S factory? Or maybe a batch of out-of-spec gaskets? I think I'll check the other side just in case...
Andy
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Sounds like a simple fix....
Richard 1976 4/4 4 Seater
Posts: 1,562 |
Be careful with these head bolts , S&S specify some very specific torque settings and tighten up sequence for these. Details on their website.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
The new seals are made of aluminum coated with a Teflon kind.
