4 members (Carbuilder, B3MOG, Morganmike, JohnHarris), 155 guests, and 15 robots.
+8Rich 103
John V6 66
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,506
AlexCreasey
DaveW Offline OP
Bear in mind that when the Roadster Sport was introduced, (09), the front cross tubes were made a bit wider on the Roadster.
So - 2005 Roadster - distance between kingpin centres at the bottom - 1030mm; 2012 4/4 - 1030mm (40.5"). The same width.
Rear axle, spinner to spinner measured externally using my tracking tool:
2005 Roadster 1693mm. 2012 4/4 - 1693mm. The same. This confirms my theory that the difference in width is down to wheel offset.
Rear wing width measured from the top, from side of body to edge of wing - Roadster 20cm. 4/4 16.3cm (each side).
And the 2 litre zetec sump is not the lowest point. it's tucked up well away from harm. The low point apart from the gearbox crossmember is the bellhousing but there's over 4.25" clearance which is an inch more than the Roadster sump.
OK, ok , so you've got TWO Mogs to measure......stop bragging!
It obviously went well today Dave. Congrats.
Nick
DaveW Offline OP
Well, tired after the trip, but not too tired to get the tape out.
Plus my hawkeye neighbour who sussed me out within five minutes of getting back...............
"Collecting them are we?" he said
Drive on the Wild Side
It's not the the width that's important innocent
Adrian
DaveW Offline OP
Is it the rhythm?
Because that's going to get you. getcoat
Originally Posted By DaveW
Is it the rhythm?
rofl rofl rofl
Adrian
I thought you needed a narrower car - presumably it did fit...?
Looks like you've only saved 7cm?
DaveW Offline OP
The most crucial 7cm in the world...................
And yes it does fit - just.
Congratulations. Not just on the new car, but on finding two symmetrical Morgans! What are the chances...?
Stuart
rofl rofl
