1 members (Image),
260
75
Topics49,870
Posts837,669
Posts: 870 |
Looks like the bottom pulley to me. Look at the shape and colour of the head protruding through the casing. That looks like one of the top ones to me. I wouldn't request anything, I'd DEMAND an new engine. You know they have plenty of them ready to go in the factory. Hear, hear!
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Looks like the bottom pulley to me. In my opinion you are unlikely to get a replacement engine as it's a simple fix given a new casing/pulley/nut. That's going to depend upon whether the cam belt stayed in one piece and didn't slip. There also doesn't look to be a lot of room for that top pulley to get down to the bottom of the case so who knows what damage it's done on the way. I'd be in the new engine camp myself.
1972 4/4 2 Seater
Posts: 12,261 Likes: 319
Posts: 12,261 Likes: 319 |
It should be a straight warranty claim by MMC to S&S I would think. Not sure why a new engine is required unless other damage has been done.
Gone to Porsche Part of the Furniture
Posts: 4,333 |
There is a lot of parts bouncing around and moving up and down when that Motor is running, who knows what damage has been done that might only show up long term. 13months later and 1 month outside of warranty, then something starts to rattle or wear  new Engine
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Doesn't look like top pulley, more like crank pulley that drives the three camsafts, nut has dropped off and pulley has worked its way along the nose of the crank and pushed through the casing, just whip the front cover off and fill hole with isopon, pop the nut back on with some loctite, refit casing and you are mobile again until MMC sort a permanent repair
Posts: 164 |
Posts: 37,435 Likes: 979
Posts: 37,435 Likes: 979 |
Sorry to hear of your engine failure and hope they can get you up and running while the weather lasts.
Posts: 414 Likes: 6
Posts: 414 Likes: 6 |
I'm not really familiar with Motorcycle engines, or the S&S in particular...but are they "interference" engines? i.e. when the timing belt fails do the valves and pistons collide in catastrophe?
Really sorry about you bad luck MrPB...but is sounds like the car still runs, correct? That seems strange if so.
1965 Plus 4 2008 997 Turbo Cab 1981 Alfa Spider 1954 Austin Healey 100 (SOLD) 2013 M3W (SOLD)
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I would go along with Easter on this, it is not in a "wet" area, it was running OK when the damage was noticed so the cam belt was still in place with no valve or drive train damage. It looks like the nut has undone and damaged the case. Torque it up and lock it, check the drive belt condition, temp repair the cover and use it until the replacement cover arrives. Fairly certain it's not as bad as it looks, not an engine change but a competant S&S engineer will know. I assume a trained Morgan dealer will know for sure?
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Very sad to see and sorry to hear about the incident. Here's to getting you back on the road soon.
Richard 1976 4/4 4 Seater
