7 members (Heinz, Barry M, +8Rich, hillclimber, JohnHarris, RedThree, MJF), 221 guests, and 83 robots.
+8Rich 86
Topics49,848
Posts837,403
DazMog, The Impaler, tlchzj79
Page 7 of 7 1 2 3 4 5 6 7
JP,
welcome to the 4-wheel gang!! Sounds like you are enjoying it - now - see how hard it is to wipe the silly grin off your face!!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Fantastic - welcome to the delights of the Roadster. Your fuel gauge does not sound faulty - the Roadster has a small tank and drinks like a fish !!
David
2020 Roadster 3.7 Dove Grey.
Fuel gauge is an indication only...
Saying that it was pretty much correct on my '76 4/4, but a lot of people seem to get 3/4 indication when tank actually full... My new one may be like that...
Cheers,
My '76 fuel gauge is about right...
Glad you like 4 wheels. The fuel guage on both my Mogs only ever showed 3/4 full. I use the oddometer for longer trips 200-220 miles & refuel.
Just back from a weekend away in the Roadster - the more I drive her the better she gets. Slight panic on the outward flight, complete power loss after first stop attributed to battery securing bracket not being tightened up, battery bouncing around and the earth cable (again not tightened) leaving the terminal. So much for a pdi....
I'm also learning about the minimal ground clearance when it comes to anything other than a billiard table flat surface. Despite a cautious approach I've still been caught out a couple of times by speed humps and car parks - steady as she goes appears to be the order of the day.
The V6 engine is a joy, one moment in silent cruise mode at 2000rpm and the next an angry animal when 5000rpm approaches. Fantastic. Returned around 29mpg on a 100 mile steady run leg of the trip.
I think the mix of tech and minimalism is perfect, the car invites you to get involved but doesn't make it a chore. Feels so 'British'.
Very pleased with my upgrade from 3 to 4 wheels, can't wait for the next journey...
JP
5 Guzzi's & A Mog
Originally Posted By JP GuzMog
Well, the deed has been done and I have the Roadster.
I drove the M3W to Stourbridge on Friday to trade her in. The dealer suggested they could trailer the Roadster to me and take the 3W away, but that didn't feel a dignified way of ending a relationship. Anyway, one doesn't buy a Morgan to trailer them around.
The drizzle around Birmingham helped to confirm my decision process and eased the guilt felt when trading in something you actually quite like - hence the 5 Guzzi's...
I pulled up next to the Roadster and was shocked by how good she looked. Ferrari metallic grey, burgundy roof, mulberry leather. The spoiler was the right decision, I think it really works well and changes the look dramatically.
I had a couple oh hours or so at the dealers - spent some time with a workshop tech who put me straight on a few basic do's and don'ts, very helpful. And then off, straight into an hour and half queue on the M6. Not the most glamorous start to a new relationship. I immediately noticed that the stop/start facility isn't working and the fuel gauge must be faulty as it moves at a disproportional rate....It rained like hell on the way back, I must say those roof thingies are a good idea.
So, first impressions: Steering heavy at low speed, clutch like a piece of gym equipment, noisy at speed with roof up, bonnet like an oil tanker in front of you, no radio and no refinement. In other words, perfect. Once off the motorway things begin to make sense, a truly British experience. I don't think most drivers will understand why anyone would....but I'm working on the basis that if you need to explain, it 'ain't worth it.
Having had a thousand photos taken of the 3W I was intrigued to get an idea of how the Roadster wold be received by Joe Public - lots of looks, thumbs up and nods of approval. Maybe not quite the same level of love received as a 3W pilot, people think you are a mad eccentric and like you for it, but certainly not the level of resentment I've seen being dished out to other drivers of prestige marques.
I've spent all weekend driving around the Vale getting to know her, my conclusion is 'magnificent''. Opened her up to get past white van man and was shocked by the almost motorcycle level of performance at 4-5000 rpm. Taking it easy on the V6 for first few hundred miles but very impressed so far. Not sure how hard to push into bends yet but will build up gradually and look out for tell tale signs of the limit being reached.
A few niggles - standard steering wheel looks dreadful, will replace with leather/chrome alternative in due course. Headlight bulb blown, rubber bonnet stops missing, both sides, and a few loose bolts when having a check round with spanner and allen key.
But parked outside the local, she looked about as good as it gets, one very happy bunny.
Goodbye M3W, hello Roadster.
Greetings from a fellow Roadster owner.... I enjoyed your write up, a very similar initial experience to my own. I use mine whenever I can, although I must confess to favouring taking it out in the dry (if it rains en route, I'm ok with that).
In handling terms, I find cornering on a balanced throttle (ie neither accelerating or decelerating - just constant revs) to really suit the Roadsters design (perhaps all Morgans). Whilst this is the correct way to corner, I've never really concentrated on this in 'modern' cars as their suspension is so forgiving.
Post pics when you can. smile
+8 4.8
Cheers N - that has confirmed what I have been experimenting with, a steady brisk pace through corners seems to keep everything in check.
I also find 1st gear very short, almost worth ignoring and pulling away in second if conditions suit. 6th is most definitely overdrive.
I look forward to the Brooklands or similar wheel becoming available, the factory fit is functional and comfortable but doesn't add to the interior finish. What is it with Morgans and steering wheels, the 3W had a much criticised example?
Dry tomorrow, I think I know which car will be taking me to work.....
JP
5 Guzzi's & A Mog
