0 members (), 206 guests, and 17 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
Page 3 of 9 1 2 3 4 5 6 7 8 9
DaveW Offline OP
Some chafing pictures:
First the top edge of the scuttle:
The touch up (a Fiat yellow) is a closer match than it looks here, but you'll see in the next picture why it doesn't matter.
My solution after a bit of head scratching is a leather patch on both sides. We'll see how that goes. Secured with double sided tape.
Here's the body under the doors: frown2
This is not uncommon, and you need to check your car regularly here, although my Roadster doesn't chafe here at all.
The door bottoms were also down to the alloy, here I've blobbed some etch primer on, before top coating. You can get away with taking liberties down here because it doesn't show. It's not worth too much effort either if it continues to chafe.
This next one shows the sealant on the bulkhead, which I've now tidied up.
DaveW Offline OP
The underside is a mixture. The floors are almost pristine, having been undersealed by the factory, and have remained shiny and black. This must be because road spray stays under the wings. The wings need some serious TLC.
This picture is the nearside , showing some spattering, but also shows the limitations of factory applied underseal, (which extends into the spare wheel well - must be applied with the wheel removed because it's comprehensively black inside).
The sump is well tucked out of harms way............
I've added neoprene corners for the wheel to sit on, but you get the black picture clearly here:
This is what happens to the edge of the rear wing on pebbly roads after 12k miles:
I've treated it for now but it needs more work. The other side is not so bad because the exhaust offers some protection.
Interesting set of photos (including the wine bottles!) Dave. The factory told me that the black underseal is Dinotrol 4941.
DaveW Offline OP
Useful tip Jay - I don't really like black underseal, but at least it's in keeping with the yellow/black theme!
Would this help the stone chip problem?
http://www.halfords.com/webapp/wcs/store...tegoryId_165594
2015 Plus 4 (GDI) Sport Green
Three Morgans and not one of mine chafed under the doors thinking
Drive on the Wild Side
Looks like you've overdone the polishing around the doors innocent
Adrian
Dave is your car Giallo Fly n colour I've stumbled across the codes for graham if its the same colour?
Adrian
Thanks for the further update, interesting stuff.
DaveW Offline OP
No Adrian - Hyundai Dynamic Yellow..................
