Old Book
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
Topics49,937
Posts838,564
Posts: 22,386 Likes: 359
Posts: 22,386 Likes: 359 |
A more relaxing day today. First a look at that rear panel with the rough holes, both for the exhaust hanger, but only one needed on a 4 cylinder. This is the offside:  Hard to say whether this is best left alone or 'fixed', So I shaped some 1mm aluminium, and painted it, then used double sided tape and we'll see how we go with it: Offside  Nearside  Here's the later badge. I'm not keen, preferring the older badge, although this one is not flaking.  So here is the replacement - a bit pricy though.  Now this comes flat, so you have to apply a bit of force to get the right curvature. I used masking tape to protect it, and used the vice. So now it's curved. The washers and nylocs are from my stock.  It has a hollow back, so guess what?  The right hand hole has been slightly elongated.......  Hey presto - I like this a lot more.  More to follow.............
Next I fitted some higher output headlamp bulbs. An offset screwdriver helps with this:  One screw and a twist is all it takes to remove the unit:  And I'm suffering tumbleweed whistling at moderate speed. This is often caused by air passing between the headlamp and the rim, although the Roadster doesn't do this. So some self adhesive neoprene might just stop the whistle. We'll see.  Then I went back to the sidescreen seals and tried a bit harder. This is all about trial and error, but double sided tape allows endless retrys.   Next I fitted some hood swivels which I picked up from e-bay, but came from John Gills. I had to check Grahams car because the swivel threaded rod was far too long for a 2012 car, which only has a single frame at that end. Older Morgans have three frames to accommodate, which is why the threaded rod is so long. The photo which follows shows the original swivel. The black end is how much I had to cut from the swivel to get the right length:  And a dash clock................  And some painted drawing pins........  And that was all for today!!
Posts: 1,213 |
I agree Dave that badge looks much better .
I know you are the neoprene expert (!)and was wondering you get it from , I'm beginning to see how useful it is !
Hugh
Posts: 1,213 |
Thanks
Hugh
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
More great info Dave - thanks.
Richard 1976 4/4 4 Seater
Posts: 4,896 |
Dave, another lovely post, I may have to get some neoprene.
Adrian
Posts: 28,917 Likes: 354
Posts: 28,917 Likes: 354 |
I think the single roll I presently have just isn't enough  Another excellent post Dave
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Pic #1, already traces of rust on chrome headlamp surround
Posts: 519 |
Thanks for the post,very helpfull stuff! This also proves that Neoprene is a Morgan owner's best friend
