2 members (Ruut Bianchi, TBM), 94 guests, and 30 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,607
Peter J Offline OP
Formerly known as Aldermog
Clearly touring in a Morgan demands a tool kit as unlike the modern boxes there is a significant probability it will be needed.
Other than the means to remove wheels what do you carry?
So far and based on my limited experience it seems that a couple of screwdrivers and a selection of bulbs (or lamps if you prefer)are essential, but I'm sure there must be more.
I usually have a full accompanyment of tools in the 4/4 for most of my jaunts....cordless drill..you name it, but that's only because i'm off to the boat...see... boat
Maybe i've been lucky, but in 14,000 miles of happy Morganeering, no tools have been needed for the 4/4 while out on the road.
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
Small grease gun, screwdrivers, small socket set and adjustable spanner, cable ties, knife, pliers, small multimeter.
Retired, not expired
Don't forget the "gaffer tape", very useful for holding bits on.
Cable ties - incredibly useful, and can secure all sorts of things.
Chain splitter and selection of chain bits.
Various spanners and screw drivers.
A small kit with ratchet and bits under the seat.
A set of bulbs and fuses in the tool tray behind the seats, and a larger monkey wrench.
I also keep a Ledlenser headlight in the glove compartment.
For longer trips I also pack a plastic box with a small grease gun, 1 extra cartridge, rags, and some use and throw away rubber gloves.
4/4 2 seater 2001 model
This small socket set from Halfords for £15 contains both metric and imperial sockets plus screwdriver bits. Apart from what everyone else has mentioned I carry a spare plug lead and a spare damper blade.
1972 4/4 2 Seater
Similar for me:
Small spanners
A few screwdrivers
Adjustable spanner
Small grease gun
Small can of motorcycle chain lube (for rear springs)
Set of bulbs & spare fuses.
Spare relay (suits fuel pump/cooling fan etc - carried after the fan relay failed on one UK trip)
Cable ties
Gaffer tape
Tube of Bostik glue (carried after a hood rubber seal came loose on one trip)
Most go neatly into a small canvas tool roll and then stored on the floor behind the passenger seat; the rest go into the tool tray under the rear shelf.
We have taken the 4/4 to either France or Northern Spain every year for the last 8 years. drive
Absolutely fantastic trips.
I also carry a hood cover, a steering wheel lock and a wash kit (comprising a collapsible bucket, small sponge and drying cloth): plus warning triangle (2 needed in Spain) and 2 x reflective tabbards.
Bud
4/4 "Stanley"
Never done any really long trips such as outside UK
Tools are a selection of spanners/adjustable spanner/screwdrivers/multi torx and allen keys/bulbs/cable ties (awesome make-do items)/fuses/kitchen roll/microfibre towel/fault code reader (when remembered!)Small greasegun for longer trips.
Tools are in tool tray in rear,rest under the seat.
Cosmetics carried for my maintenance...... lipsalve/sunscreen
Don`t forget the WD40 - to disperse water, free seized up bits and handy for removing bird crap from the paintwork.
