8 members (PaulV, Zach, RichardV6, Morganmike, JoeSpeetjens, Clipper, DCH, teknome),
366
95
Topics49,867
Posts837,612
Posts: 28,901 Likes: 352
Posts: 28,901 Likes: 352 |
Are you sure it's the engine that is offset???
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Go and stand in the corner Graham..........
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
It does make one think that the LHD cars are easier in that they don't habe an exhaust/brake master cylinder conflict, Roadsters excepted..!
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Interesting as ever. Odd block alignment.
Richard 1976 4/4 4 Seater
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
An excellent and informative post, thankyou Dave
The offset is only really obvious from below Richard, when I started to cut out a cardboard template, and it wouldn't fit symmetrically. Bear in mind that the gerbox is also canted over to the nearside at ten or fifteen degrees. The crank is about two inches from centre based on the crosshead struts. Even so the alternator is a tight fit on the nearside. Loads of cars have had offsets, probably the most well known being the Escort Twin Cams, which needed offset to make space for the carbs. Offset irritates my OCD tendencies, I like things squared up, but then again with a transverse engine, the whole thing is untidy. And if you ever look under the bonnet of a Lancia Fulvia....... well.........
Posts: 113 |
Lancia Fulvia, worked on them a lot many years ago, i never noticed that. If i remember the engine is a "17degre V on a 45 degre slant"
I "struggle" with my angled prop/tunnel.
I might have mild OCD but prefer to write it CDO.
Posts: 1,948 |
Looks like it's been tipped in using a wheelbarrow... Wife had a Pug 205 when I met her and I thought that was untidy under the bonnet...
Stuart "There's no skill substitute like cubic inches."
