2 members (RedThree, yobtaf), 383 guests, and 38 robots.
Topics49,860
Posts837,486
Jonny72
The Rover V8 is an old design so works best with 20/50 in my experience. The design is noted for being high volume/low pressure, and the standard of the day where there was a pressure gauge, was not to have a warning light. My V8 used to run a whiff over 30psi at 3k rpm, but would be low at tickover. To be honest I can't now remember what that was. It was the basic cover with distributor drive. In 1972/3. MG were inundated with complaints from MGB ovners who had bought a V8 and thought the pressure wasn't good enough (compared to the 1800). The solution was to fit an uprated relief valve which upped the pressure from high 20's to low 30's psi. There was also available an adaptor plate which fitted under the pump cover, and accepted deeper pump vanes to provide more capacity, but I didn't try one. The MGBV8 had a remote filter, which is why the pump had a cover plate. There will be pressure at tickover, start by bleeding the pipe at the gauge end!
E
E
When I re-built the engine in my 71 Range Rover years ago I seem to remember packing the oil pump gears with vasoline to help get the pressure up initially, but it always ran with a comparatively low oil pressure.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
Terry Offline OP
Thanks Adrian, I'll try another oil, I have been using Castrol GTX 20-50. Many of the fancy synthetics 20-50 don't seem to be available in Oz. I have found a couple they say are for big bikes ... I don't know what is special about them.
Castrol recommends Edge 15-60. Penrite HPR 15-60 seems close to the mark also.
I would appreciate advice, especially about oils available in Oz.
I have found another gauge to check the pressure!
Terry
GoMoG has some new info on this here.
