8 members (Bilymog, linklaw, DavidR, Strathaven, Bunny, Graham, G4FUJ, lez, TalkMorgan), 184 guests, and 36 robots.
+8Rich 99
John V6 55
Topics49,906
Posts838,104
#164582 08/11/13 03:04 PM
Has anyone replaced the standard M3W battery with a lighter, perhaps more efficient Gel type battery?
I put an Odyssey one in an S7 and it did crank it over better too, my M3W sounds lazy to start.
Can't comment on an M3W, but I put an Odyssey Battery on my 4/4 and it is very good. The battery is under-bonnet, thus quite small.
thumbs
Bud
4/4 "Stanley"
Lots of classic 3W owners use the Odyssey PC680 with good results. Some without generators use two of them (because they are only 17 amps?).
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #164616 08/11/13 07:49 PM
SBM Offline
I can only add my thoughts here, but having worked with Harley twins of various sizes we had a lot of issues with apparently weak batteries when starting those high compression vee twins.
When we researched a little deeper, the culprit was a non-HD battery we offered as a cheaper replacement. The figures that matter are the 'Cold Cranking Amps' or CCI, which the manufacturer will declare on any adverts or info etc.
If that hits the target, and it's cheaper/smaller/lighter etc, then the jobs a good 'un!
SBM #164639 09/11/13 02:02 AM
Odyssey batteries are about as good as you can get these days, with shelf lives of a few years, properties of deep cell technology, ie, they can survive deep discharges w/o issue and plenty of cca's. I will certainly make the change from my stock battery a little down the road.
An interesting thing to note for those of us in the States, Sears Die Hard Platinum batteries are rebadged Odyssey's, and a fair bit cheaper. Unfortunately they don't come in a M3W size, but if your in the market for your normal sized vehicle, it's a great battery.
2000 G500, UNIMOG 1550L37 DoKa, M3W
