Goodwood
Topics49,931
Posts838,506
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
I managed to blow the brake lamp fuse this afternoon, (stupidity) so had to look up the fuse layout. This was it in 2005, and the main box is still the same on Bumble. So just for information - here's the list.
Relays:
E........................ D....................... C.................. B................ A.............. Cooling Fan High..... Cooling Fan Low..... Ignition ECU..... Fuel Pump..... Starter
Fuses:
Primary Box: 1 30A Ignition Switch 2 30A Starter Relay 3 30A Fuel Pump & Ignition 4 40A Cooling Fan 5 30A Air Con 6 20A Dash Module 7 20A Engine 8 20A Main Fusebox
Main Box: 1 15A Engine .............. 11 7.5A Nearside Sidelights 2 15A Engine .............. 12 7.5A Offside Sidelights & Dash 3 15A Engine .............. 13 7.5A Nearside Dipped Beam 4 5A Dash Module ........ 14 7.5A Offside Dipped Beam 5 7.5A Rear Fog ........... 15 10A Main Beam Nearside 6 15A Demist .............. 16 10A Main Beam Offside 7 15A Heater .............. 17 10A Radio & Courtesy Light 8 10A Wipers .............. 18 15A Sidelight Switch & Cigar Lighter 9 10A Radio & Horn ........ 19 15A Fuel Pump 10 15A Indicators & H/L Flash ........ 20 15A Reverse & Brake lights
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Useful info as ever Dave.
Richard 1976 4/4 4 Seater
