5 members (nick w, John V6, jbk, Chris99, RickyH), 375 guests, and 31 robots.
+8Rich 99
John V6 55
Topics49,905
Posts838,102
#165360 13/11/13 08:12 AM
109er Offline OP
Plus 4 - 2009
I have just fitted adjustable "Rutherford" AVO shock absorbers. They are definitely an improvement over the orignal Sachs dampers.
After some fiddling I ended up with the follwing adjustment, starting from fully counterclockwise (softest):
rear 1 click
front 3 clicks
Has anyone found other adjustments useful?
Andreas
Andreas
+4
109er #165365 13/11/13 09:07 AM
Mine (front only) are on the softest setting and work just fine.
I have them newly fitted at the rear to complement the Suplex front end. They are set at the middle setting & seem OK
John V6 #165372 13/11/13 09:45 AM
I have AVOs all round with standard factory front springs and five leaf rears.
After trying various settings, I have settled with 2 clicks front and 1 click rear.
This seems to be the best compromise between handling and comfort, on my car.
Philip.
MonteZooma #165384 13/11/13 12:22 PM
5 at the front on my 4/4 sport and koni's at the rear with 4 leafs
maybee i will again try later the avo's at the rear .They were
at 0 but still too hard.Now the car has 12000 km a becomes softer.
At the beginning the front were also on 0
109er #165404 13/11/13 02:57 PM
Originally Posted By 109er
rear 1 click
front 3 clicks
There were some threads on this about 18 months back, and if I recall, that is pretty much what most people seem to think mis best. Very much a matter of personal taste. Don't forget that if you go on a trip fully loaded with co-pilot and all her luggage you should increase the rear setting one or two clicks.
Gambalunga #165548 14/11/13 06:25 PM
4 all round for me - Roadster.
I'll be interested to see what works on the 4/4-Plus4.
Drive on the Wild Side
Richard, when I took Rosie to New Elms to get her checked over, my rear Avo's were set at softest setting, Darren told me off saying they will have no damping what so ever and recommended 2-4 on the rear and 3-5 up front. Rosi is now set up with 3 click rears and 5 up front, not to stiff and works well.
cheers
Adrian
AJSki2fly #165615 14/11/13 10:00 PM
cheers
Maybe I'll have a play then....
