8 members (PaulV, Zach, RichardV6, Morganmike, JoeSpeetjens, Clipper, DCH, teknome),
366
95
Topics49,867
Posts837,612
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The CTEK charger arrived today so I fitted the umbilical cord. Just fits to the terminals. I filed out a groove so that the wires could emerge from behind the alloy cover.  The wires are held with a C clip screwed into the timber.   Final job today was to replace the electrical tape on the door frame with Reflect-a-Cool. It looks much better and being silver, picks up the yellow reflection.
Posts: 1,502 |
You've even got a matching duster...
Oh yeah! Hard to find red dusters though......
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
Dave,
I suggest you replace the standard ctek battery connector with the rather better version which has battery charge indicators and also a fuse. I am certainly against having a direct connect to both battery terminals without proper protection against a possible short circuit. Easy to catch that lead in the seat runner and a fire is not a good idea.
Neil
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Nice work as ever Dave. Interesting to see the HoE mirror bases.
Richard 1976 4/4 4 Seater
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Dave. On the mirror bases are you sure the blue sealant on the threads is not Loktite?
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
I fused my CTEK. I would recommend that, I once had a Mkiii sptifire in which somoene hard wired a light for the glove box without a fuse. It wasn't fun when it shorted out, though fortunately there wasn't a fire
Posts: 3,643 |
I inserted a 7amp (brown) fuse in a waterproof blade fuse holder into the positive side of the circuit. I should have fitted a mini blade fuse holder as my Morgan uses mini blade size fuses Next time I have the soldering iron out, I will so a change over.
Posts: 14,009 |
The latest CTEK cables have an inline fuse as standard....well, at least mine did!
Posts: 4,896 |
WHAT no Fuse!!! Boom!!!
Adrian
