0 members (),
292
71
Topics49,870
Posts837,668
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
As mentioned previously mine is Zircotec coated and has not caused a problem for me (It doesn't seem to be as close to the water feed as yours though.. Perhaps This from Autospecialists would be a 'prettier' solution.. Stainless Steel Exhaust heat shield Keith, Where did you source those braided pipes, and that beautiful overflow tank - was that a standard fitment on your car? Roger.
Roger South Wales 2003 4/4 (Meg) Connaught Green
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
A very well dressed engine indeed.
Richard 1976 4/4 4 Seater
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Apologies of late response... The header tank is the standard one with this neat AutoSpecialist header tank cover (simply sticks on top with double sided pads). Header Tank Cover Also they do a nice cap cover as well.. Header Cap I tweaked the position of the tank slightly to get it tucked under the heater box overhang and I was pleased with the result as well. I used Stainless Braided fuel line available from CBS Online Stainless Fuel Line and remember the address is... Father Christmas Lapland......
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Thanks for the info Keith.
Posts: 287 Likes: 1
Thanks for the info Keith. +1.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Keith, you are becoming King of Bling........
Posts: 1,502 |
So speaks the Queen of Neoprene...
Posts: 287 Likes: 1
Keith. By the way, what do you use to provide a good end-detail on the pipes? Roger.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I'm considering replacing the standard rad in my (low mileage) 2005 4/4 focus zetec (i.e. 1.8 blacktop engine). On recent hot days, driving at "comfort" speeds - not thrashing - over the moors, the fan has been running almost constantly when the engine is under load, usually stopping only when running downhill off the throttle, or idling. Temp gauge is showing 100-105 deg. I'm pretty sure the fan is operating normally as when starting from cold and leaving the engine to idle, it comes on after a few minutes and cycles normally - it is when driving that the constant fan running becomes evident. With this "performance" I would be loathe to take the car somewhere really hot or to the Alps etc. The only modification to the car is a Librands 4-2-1 s/s manifold and sports exhaust system which did increase power (about +15 bhp on dyno), everything else is standard. There are no badges or other obstructions to the grille. The car has been regularly serviced and the cooling system checked, no leaks, two hoses recently replaced (preventatively - chafing) etc. The Mulfab radiators are described as about 15% greater surface area, which doesn't sound an awful lot. There is a heavy duty racing version, presumably bigger again? Having the correct mounting points and hose positions would be important. http://www.mulfab.co.uk/our-products/20/aluminium-radiators-cooling-systems/aluminium-44-radiatorsDoes anyone have any experience of these radiators, or any alternative suggestions? I will contact Peter at Mulfab for his advice too. Thanks Nigel Hello Nigel, I realise this is from some time ago but I wondered if you resolved the hot running issue? So far I have: Changed the thermostat Changed the radiator for a mulfab one Made and fitted an undertray to reduce back pressure in the engine bay. Made and fitted an intake cowl to duct air in below the bumper Moved the number plate so that it's level with the bumper Removed the stainless steel mesh behind the grill Made and fitted side cheeks to block off the area between the rad and the cowel AND - still the fan comes on, even in this weather so I would be very interested to know if you had any success? Thanks and regards Simon
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Simon,
At what temperature does your fan switch on?
I can't remember, which engine do you have?
Bob
