Topics49,844
Posts837,357
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Great job, boys!
That's what TM is all about..
Posts: 1,562 |
Thanks Chris,
I have a few as I fitted the guard which I will upload tonight after I have fitted the rear bracket and had a tootle round the block. And thanks for the link as well , I couldnt find it for some reason.
Graham
Posts: 1,562 |
Hi Chris, Forgot to say , as per the pioneering links, I got mine from Indespension , their part number MG008. http://www.indespension.co.uk/Plastic-Mudguards/MG008.htmlDont be put of the description being for a 13" wheel - this the right part for the M3W. Also call into your local branch if you can - I was ripped of for £9 postage ! Graham
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Thanks Graham,
I'll pick one up next time I pass my branch.
Red Leader
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
I would like to see more pictures for the fitting of the rear end, I have the mudgard from the german link somewhere in this forum  and it fits perfect, but it is not yet fixed.
Posts: 1,562 |
Mudguard as supplied , with factory mudguard laid on as template Plastic mudguard cut to shape If you cut the plastic mudguard up to the fold in the factory one , you clear the drive belt - do a test fitting ! Drilling through , using the factory holes. I had also fitted three bolts above these at this point as extra security - after cutting the plastic mudguard I was concerned about the amount of strength it had lost , so fitted extras bolts. Probably over kill. Use plenty of clamps ! Trial fitting - still not enough clearance for the drive belt , so I took some more off that side. Long distance shot of the trial fitting Bending up a length of steel bar ~I had to hand for the rear bracket. I used the angles of the inner wood frame , at the position of its final placement as a guide. I am not proud of the rear bracket as a piece of engineering - but it is hidden out of view and will have to do ! Close up of the angle Terrible photo of the complete bracket. I chose to use a tee peice from B&Q to bolt onto the plastic mudguard. Bracket bolted onto the mudguard , still checking all clearances. I have pulled the plastic mudguard up out of position in the boot here - it is fairly flexible. Final shot of the tail bracket fastened up. I chose to fasten mine to the upper woodwork - I believe others have fastened it to the lower woodwork - whatever you find easiest !
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
I dont understand your adaptation You fixed the mudguard on the bottom with the "bras oscillant " And you fixed the upper on the chassis. How could it move?
Posts: 1,664 |
If it is like mine, it is plastic and can flex the small amount that may be required of it on occasion.
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 1,562 |
If it is like mine, it is plastic and can flex the small amount that may be required of it on occasion. Exactly - By pulling the whole mudguard out of the boot space while still attached ( second to last picture ? ) you can see these plastic mudguards are extremely flexible and able to take severe bends without problem. Besides which , the rotation back at the swinging arm in normal use should be pretty minimal - I think the swinging arm would hit its stop before it became a real problem to the mudguard. I will report back and problems I have after I have put some miles in.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Looks good. Great how to.
Richard 1976 4/4 4 Seater
