2 members (jejemek, sezznowt), 240 guests, and 37 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Christoph
Page 6 of 8 1 2 3 4 5 6 7 8
I have yet to fit my set. As I have a concern.
When greasing the suspension using a grease gun from the top and bottom nipples I can watch for the grease oozing out.
The number of squirts needed varies each time I do it.
So the concern is that I cannot see the grease oozing out if I use the remote kit.
I have considered installing the remote nipples near the suspension, in a position where I can see the grease oozing out.
Ian
Gentlemen,
Thank you for the responses so far
My MOG is a 1999, 1800 Zetec, 4/4 2 seater and my local dealer has quoted £215 incl VAT
With Kind Regards
The Impaler
£215? shocked2
The kit is around £50 and I've seen it advertised as fully fitted by a dealer advertising in Miscellany for a lot less than that!
I am in India right now so I can't check my bill but Mogworks charged me max 1 hr labour = £55 + vat. THey are in High Wycombe so the fuel costs will be well below the savings
Drive on the Wild Side
Originally Posted By The Impaler
Gentlemen,
With Kind Regards
The Impaler
HOW MUCH!! I purchased the nipples, tubing and brackets direct from Nipplesdirect before the kit was widely available at the costly sums of £36 plus postage. It took about 1 hour to fit. see Nippleshop Morgan Kits
Adrian
Adrian. There isn't really a company called "Nipples Direct", is there?
laugh2
Bud
4/4 "Stanley"
Looking at the downloaded fitting instructions from Nippleshop, they talk about needing to slacked the bottom shock absorber nut. Anyone know the torque setting for retightening this bolt?
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Formerly known as Aldermog
So two of us in India...
what is the probability of that!
Hyderabad today, Mumbai yesterday, Delhi on Thursday.
It's not critical Roger, it's a nyloc and from memory 18/22lbs ft is the ball park. I just nip them up until 'tight'. It's only a holder, it doesn't do any real work, because the force is at 90degrees to the fastener.
Roger.
Does your 4/4 just have nipples a the bottom of the springs? (Mine does, and is the same age)
In which case you may wish to consider the following: It is possible to over-grease at that point, in which case you risk grease coming up from the greasing point, through the spring coils and going onto the brake discs.
By crawling under the car with the grease gun, you can check on this each time you greaee.. . . . . just a thought.
Bud
4/4 "Stanley"
