2 members (sewin, Tony Quinn),
262
53
Posts837,962
Posts: 425 |
All this radiator talk has made me feel a bit guilty and that aside the inside top of the header tank is covered in a sort of white scum. So I feel a coolant change and a header tank washout is due. Could any of you good people give me any pointers as to the best way of going about the draining and refilling of a Duratec 2 litre. I can't see a drain plug for the block for instance, nor can I see any bleed taps for excluding air when refilling.
John 2015 Plus 4 (GDI) Sport Green
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
+1 for an 1800 Zetec. I feel the same job calling, mainly because I can have no idea when the previous owner may last have done this.
Roger
Roger South Wales 2003 4/4 (Meg) Connaught Green
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Take the bottom hose off John and stand well back. Get the filler as high as possible to refill, and expect to bleed the heater - (slacken upper hose and let air come out with engine running) - very carefully.................
Posts: 4,896 |
John, white scum is not a great sign, how many miles has your car done, not wishing to worry you but might be an indication that the head gasket is getting a bit tired and your beginning to get oil into the water hence the scum. I would suggest you get the cylinders pressure tested at a local garage to check all is ok.
Adrian
Posts: 425 |
Adrian, good point but the car has only done 10,000 miles and the oil itself seems quite clear. I have a feeling that the scum is a result of the coolant being squirted into and hitting the underside of the header tank at quite high pressure. I have noticed this especially just after start up.
Thanks for the tips Dave, very useful
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
You may have a drain plug in the block too.
Richard 1976 4/4 4 Seater
