10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 273 guests, and 42 robots.
+8Rich 91
Luddite 50
Posts837,969
#167326 24/11/13 06:44 PM
All this radiator talk has made me feel a bit guilty and that aside the inside top of the header tank is covered in a sort of white scum. So I feel a coolant change and a header tank washout is due.
Could any of you good people give me any pointers as to the best way of going about the draining and refilling of a Duratec 2 litre. I can't see a drain plug for the block for instance, nor can I see any bleed taps for excluding air when refilling.
2015 Plus 4 (GDI) Sport Green
+1 for an 1800 Zetec. I feel the same job calling, mainly because I can have no idea when the previous owner may last have done this.
Roger
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Take the bottom hose off John and stand well back.
Get the filler as high as possible to refill, and expect to bleed the heater - (slacken upper hose and let air come out with engine running) - very carefully.................
Drive on the Wild Side
John, white scum is not a great sign, how many miles has your car done, not wishing to worry you but might be an indication that the head gasket is getting a bit tired and your beginning to get oil into the water hence the scum. I would suggest you get the cylinders pressure tested at a local garage to check all is ok.
cheers
Adrian
Adrian, good point but the car has only done 10,000 miles and the oil itself seems quite clear. I have a feeling that the scum is a result of the coolant being squirted into and hitting the underside of the header tank at quite high pressure. I have noticed this especially just after start up.
Thanks for the tips Dave, very useful
You may have a drain plug in the block too.
