0 members (),
126
36
Old Book
Topics49,940
Posts838,603
Posts: 4,660 Likes: 129
Posts: 4,660 Likes: 129 |
Like the winged badge, and I prefer to see a filter cover - think the plain black is a llitle too utilitarian looking.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Q8 - I think you need one of these [url=[URL=http://s853.photobucket.com/user/ozcoxy/media/M3WHead_zps1296599e.jpg.html] [/URL
Posts: 1,338 |
Hahaha...i have this on my ford model T [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps4f86451a.jpg.html]  [/url]][/url]
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Clay Smith Cams - Mr Horsepower
Posts: 14,751 Likes: 158
Posts: 14,751 Likes: 158 |
Now that could be used to define the word "bling"
Posts: 1,338 |
Guys i need a quick easy fix..the m3w takes to the right when i let go off the steering..can some one show a pic
Posts: 1,562 |
Apologies if you have already checked these , this is what I would check for in this situation, in this sequence:
Check Tyre pressures are correct Shows the fault on a road with no camber ? Check no brakes are not sticking on - i.e. will it roll easily on the level - I can roll mine with one hand out of gear ( just about ) Get the steering alignment checked at a reputable garage - might need alignment data from a Morgan dealer
As instant no brainers thats all I can think of - hope this helps.
Posts: 1,338 |
Did top 3..but alignment worries me abit.because i only need abit and i need a professional to do it...
Posts: 1,562 |
Unfortunately sounds like wheel / steering alignment needs checking - at least ruled out. No harm in having it checked ( with the correct data ) - having it realigned is another matter !
Hope it works out for you
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Sounds like alignment should be checked/adjusted but make sure that somebody is sitting in the driver's seat for ballast when it is checked.
