6 members (MATTMOG, deano, Julian BB, Alan Patterson, Image, Roady), 333 guests, and 52 robots.
+8Rich 79
Topics49,859
Posts837,512
Jonny72
David G Offline OP
Originally Posted By nippymog
David : that new riser looks like unprotected steel in your photos, can you see any reason why they shouldn't be blackened like the rest of the gear in that area ?
Hi The new riser is actually stainless steel,but if you like it could be painted black.
,,BSA Goldstar,Honda CB1100R. Jaguar FTypeS Porsche Cayman S
PJB has shed some light on the Suplex shocks in another thread
Originally Posted By PJB
I have been informed by the MD of SUPLEX that SUPLEX now have the development upgraded front suspension unit for the new M3W. These will replace the current SPAX units and will actually be more sophisticated than the SUPLEX units fitted to the first cars produced. They incorporate:
1. Rising spring rate with a main spring and a 'spring assist' on the damper rod. So a soft initial rate to reduce 'kickback' then stiffens in bump and cornering to reduce 'bump steer'.
2. Rebound spring incorporated in the damper to reduce roll by not allowing the inner wheel on hard corners to droop, thus also reducing 'roll steer'.
3. Adjustable main spring so that the designated ride height can be set for all weights of passenger to ensure rebound spring is just kissing at static ride height.
4. Adjustable damper bump & rebound together.
Should be good - regards PJB
HJP Offline
More good news ! smile
Hugh
Any idea when or if the factory started installing this suspension set up on all production M3Ws? LarryS
David G Offline OP
Hi Larry S,
Sorry its taken a while for me to reply but I needed to find out from the factory when the modification to the new cars had taken place.
Basically I am told that cars on build now have the modified steering set up.
Regards David
Have you driven the 2014 3W as well as the existing model fitted with the "Comfort Pack"? The parts look quite different...
