10 members (Sir Percival, +8Rich, 1560, SteveT, How, verysideways, Mats, ScotiaSteve, Moggo, HJP),
324
50
Topics49,863
Posts837,565
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Alternatively Roger, you might want to check this… http://www.ebay.co.uk/itm/Audible-Flashe...=item3382c7738fI fitted this some time ago, direct replacement for a 3 pin. If the buzzer is not loud enough you can carefully drill the casing to let more sound out, and tape up drillings to quieten down until just right, regards john k
1993 T16 +4 Lancia Blue.
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
Alternatively Roger, you might want to check this… http://www.ebay.co.uk/itm/Audible-Flashe...=item3382c7738fI fitted this some time ago, direct replacement for a 3 pin. If the buzzer is not loud enough you can carefully drill the casing to let more sound out, and tape up drillings to quieten down until just right, regards john k Thanks John. Lots of options here. Roger.
Roger South Wales 2003 4/4 (Meg) Connaught Green
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
I tried one of these flasher units but it buzzed continously. Does anyone know why. If it works it is a very simple solution.
John R 1992 plus4
John 1992 plus4 connaught green
Hi John R, presumably the flasher relay fits in a 3 pin block so unlikely to be wired wrong. If the buzzer is the same as the link then can only think the unit is faulty?
Is it exactly the same make / type? and was it located in the block, thats all i can think of, need an electrical wizards advice i reckon.
Mine works as it should and i would guess your wiring same as mine. regards john k
Hi John K,
Yes the flasher relay fitted straight into the three pin socket and it really surprised me that it did not work. That is why I went to the CBS's kit, which, although straight forward, required a bit of wiring and soldering.
John R
