2 members (TBM, Bishmog), 262 guests, and 86 robots.
Topics49,847
Posts837,389
Page 7 of 12 1 2 5 6 7 8 9 11 12
If you are a BSD you may be well hung already.
Did anyone mention what mods they have done to the compensator
Originally Posted By DaveW
BSD? thinking
I had to google it too!
PaulJ Offline OP
It's all right AsboJ, hanging has been abolished now, even here, and we're a forgiving lot...........AREN'T WE?
BSD - Big Swinging Dick, I love it! Just a thought, maybe we are all Dicks for buying such a small impractical and expensive toy car? In my case I appear to have been a double dick.
Originally Posted By Blake
-better build quality/qc. tolerances are still garbage. all my body panels rub against each other in places they shouldn't which have rubbed off bits of paint. my body has eaten through the rubber bits around the roll bars due to dermot alignment and created nasty sounds right behind your head.
-complete rerouting of the wiring harness. if you take a look at a good portion of the wiring it sits sandwiched between the frame and the engine which in lots of cases has caused shorts/damaged wiring because it gets crimped or severed over time
-rerouting of throttle cable (which some have already done in the aftermarket (i know melvyn has done it and i've had it done through a local guy)) to get rid of the unsightly cable sticking up form the engine
-fix the gaps under the dash flanking the bit of upholstered leather above the transmission tunnel. next time take a look and stick your hand in there, you can grab a handful of wiring. very unfinished looking
-rear mudguard/fender
-did i mention fit/finish QC?
-floor mats that don't move around, especially the one by the pedals on the driver's side
-reengineer the bit of framing that is at your heel by the pedals. makes for awkward positioning of your feet
-trim down the tranny tunnel. another mod that people have done independently (getting mine done this winter). there's another inch or so of width that can be reclaimed for your legs (waldemar had this done as well)
-glove box mod
-redo engine mounts. for those of us who have had to witness the engine being pulled (mine has been pulled twice and i've seen kevin's pulled 3 times) it's absurdly complicated to pull out and even worse to put back in. part of the problem is that when the car is assembled it's easy to put the engine in without the body on but once the car is fully assembled and body is on it's a mess to remove and put back. i've talked with a couple buddies who work on race cars and they've all had some great suggestions for redoing the part behind the numberplate which would allow you to pull the engine directly out
-all the rough topped hex bolts in the interior where the leather seat pads sit against which after the first month of ownership will end up cutting in to the leather and pretty much destroying your seat cushions. if you don't believe me pull your seat cushions up and look at them, they look like hell
-on a similar note to the seat cushions, work on the rough edge of the body where the top of the seat back is pinned underneath/behind, it also cuts in to your leather. was super disappointed when i pulled my interior apart to do my dynamatting which revealed what poor shape everything was in
-find a way to change the rear tire without having to spend a couple hours pulling everything apart. it's really really really complex to get the thing off and requires a proper lift. not something that could ever be done when dealing with a flat on a trip
-louder! i agree with peter. car needs more nuts to it. when i got to hear the ace cycle car i realized how gutless the morgan sounded. not looking for an obnoxious harley sound but just something with some more meat to it.
-fix the pinging sound at high rpm
-faster. would love to have the 4.6 sec car that was advertised to us. our cars are quick but not fast. while i realize that too much power would be lethal in these things i do feel like it's being substantially held back
bitches aside it's a blast to drive but in the spirit of constant improvement it's important to be fully open and honest about the cars shortcomings or areas that could be made better.
Many thanks to Simon for offering to bring Blake's suggestions to Malvern. He's done more work that anyone I know of in the US to fettle his car, and we've all benefited tremendously from his insights...
And to add to Blake's excellent suggestions:
1) Engine turned dash with Smiths Gauges and no digital readouts whatsoever.
2) A more eager powerplant. I realize a torquey V-Twin Harley motor fits the bill on the marketing side of things, and it certainly looks great out in front, but I find the engine to be a touch lazy and, dare I say it, it imparts an "agricultural" feel to the car. Something lighter, a bit more high spirited and high reving would fit the character of the car a bit better IMHO.
3) A proper shop manual/parts manual for those owners who live outside the UK and far from a dealer and who will need to do some of their own maintenance. It's troubling that the user manual doesn't even include service intervals or a list of work that should be done at each service interval. There's little guidance on performing even "basic" maintenance like rear belt tightening.
4) Too many creaks and rattles, well applied resonance dampening would improve perceived build quality tremendously.
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
Two more:
Mazda now has six speed trans for the Miata (possible drop in?)
An accurate speedo would be nice as well (I'm getting tired of figuring out the 8-10% miss in accuracy while on the go)
le Asbo du Bling
le Asbo du Bling
Originally Posted By emiguy
Two more:
I asked about this some time ago, the response I got is that its larger so less room in the cockpit.
Slowly going green
SBM Offline
For Heavens sake, keep a five-speeder please! Six is always one too many. It's only a torquey vee-twin, and my hands have enough to do..
couldn't agree more
4 speed would have been fine in a beefed up gearbox. I am worried about long term effectiveness of the torque compensator and knock on effect to transmission
le Asbo du Bling
le Asbo du Bling
They did show me the inside of one but without the old one next to it I don't think I could answer the question.
The 2014 car I tried had the new Centa Drive as its called. I've worked out how not to make mine sound like a bag of loose spammers when pulling away, I tried opposite on the new model and I couldn't get it to happen.
Slowly going green
