Topics49,880
Posts837,756
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
I'm looking for a couple of small enamel Welsh Dragon bonnet badges, but the only ones I can find are from Melvin Rutter, which require drilling holes to fit. Does anyone know of a source for self-adhesive ones?
Roger South Wales 2003 4/4 (Meg) Connaught Green
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Or you could glue in screwheads and then use self-adhesive...
Richard 1976 4/4 4 Seater
Posts: 287 Likes: 1
Diolch yn fawr, John. If I can't find enamel ones these might well do the trick.
Posts: 14,009 |
As Richard said, you could try the bolt on type with dummy screw heads and trim tape. I did that on my 4/4 bonnet and they look better than the ones with the "proper" dummy screw heads. I just araldited a couple of stainless pan head bolts on and then cut them off behind the badge.
Posts: 425 |
John 2015 Plus 4 (GDI) Sport Green
Posts: 2,814 |
Double-sided sticky tape- used for number plates? Gerry.
Gerry
Posts: 287 Likes: 1
Nice one, John. Much obliged.
Posts: 9,548 Likes: 133
Posts: 9,548 Likes: 133 |
Melvyn's badges are good ones - the Dragon is a good one! i replaced my Union Flag ones with his - bonnet was drilled so an easy swop. Double sided tape is a good alternative and a good finish with cut off screw heads adds the final touch. If the badge has a curve then someone I know flattened them a bit by sanding the ends a bit - bending them could crack the enamel so not reccomended.
