7 members (Eastertown, Paul F, DaveW, Carbuilder, +8Rich, Saxonian, Craig Jezz), 239 guests, and 84 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,878
Posts837,753
#171185 16/12/13 12:04 PM
RogerS Offline OP
I'm looking for a couple of small enamel Welsh Dragon bonnet badges, but the only ones I can find are from Melvin Rutter, which require drilling holes to fit. Does anyone know of a source for self-adhesive ones?
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Or you could glue in screwheads and then use self-adhesive...
Would these be of any use. A bonus is that the fitting instructions also are shown in English! ....how very thoughtful.
http://www.ebay.co.uk/itm/Wales-Welsh-Dragon-Car-Self-Adhesive-Gel-Badge-Set-of-5-/150610557911
2015 Plus 4 (GDI) Sport Green
RogerS Offline OP
Diolch yn fawr, John. If I can't find enamel ones these might well do the trick.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
As Richard said, you could try the bolt on type with dummy screw heads and trim tape.
I did that on my 4/4 bonnet and they look better than the ones with the "proper" dummy screw heads. I just araldited a couple of stainless pan head bolts on and then cut them off behind the badge.
Double-sided sticky tape- used for number plates? Gerry.
Gerry
RogerS Offline OP
Nice one, John. Much obliged.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Melvyn's badges are good ones - the Dragon is a good one!
i replaced my Union Flag ones with his - bonnet was drilled so an easy swop.
Double sided tape is a good alternative and a good finish with cut off screw heads adds the final touch.
If the badge has a curve then someone I know flattened them a bit by sanding the ends a bit - bending them could crack the enamel so not reccomended.
