8 members (Eastertown, Paul F, DaveW, Carbuilder, +8Rich, Saxonian, Craig Jezz, Mark+4),
239
92
Topics49,878
Posts837,753
Posts: 9,548 Likes: 133
Posts: 9,548 Likes: 133 |
Bugger! It also shows a slideshow of other photos!
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
Looking good. Was replacing the flag the first thing you did when you got the car?
Roger South Wales 2003 4/4 (Meg) Connaught Green
Yes RogerS Previous owners have put upgrades etc already. I still have the old badges. Just had a roll bar fitted by Williams. About to fit a Mig clock, not in the dash-no room! Will build a "trinket tray" for transmission tunnel and fit it there as with Plus4 Supersports timing clocks. Just thinking of the final design/layout.
Posts: 287 Likes: 1
Sospan, are you closer to Williams than to Newtown Motors in Cwmbran? So far I've only used NM.
Posts: 14,009 |
Yes RogerS Previous owners have put upgrades etc already. I still have the old badges. Just had a roll bar fitted by Williams. About to fit a Mig clock, not in the dash-no room! Will build a "trinket tray" for transmission tunnel and fit it there as with Plus4 Supersports timing clocks. Just thinking of the final design/layout. I'll be intrigued to see where you put your MIG clock! Did you go for the 3 dial version?
Yes, 3 dial version. 2day movement Main dial for time Flight duration dial - 12 hour Stopwatch dial -60 min 2 operating knobs Came from Ukraine, as used in Migs 23,25,27,29
Williams is further and they did a mate's roll bar . Excellent job done. Haven't used NM. Done my own servicing so far. Williams did oil/diff/brake fluid for me at same time though. Saved jobs for me! Leaves time for others - Under seal to be done,general nut and bolt checks,leather touch up etc
Posts: 14,009 |
Just like one of the clocks I got....we probably bought from the same guy in the Ukraine! Look forward to seeing how you incorporate it into your cockpit.
Posts: 287 Likes: 1
I think NM are a relatively new Mog dealership, and Meg (the Mog) is still under warrantee with them, so I'm happy to see how they perform for this first year (so far, so good). Best of luck with the underseal; big job.
