Topics49,904
Posts838,092
Posts: 318 |
Hesketh will use the S&S engine on their new bike, Hesketh 24. See link; http://www.heskethmotorcycles.co.uk/hesketh-24/Rudolf. :xmastree:
Morgan Aero8 S4 «Tango» Fisker Ocean Harley Davidson Livewire BMW R100/7 , R100R Moto Guzzi 254
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I can't understand why, if the motor is sufficuently cooled when cramped up in a frame with one cylinder masking the other the M3W, with the two pots open in the breeze, it needs additional cooling....
Posts: 318 |
Normally the two cylinders are placed off-set in a V-twin configuration.Meaning the aft cylinder is still partially in the airflow. The engine in the Hesketh has probably a lot easier life than in the Morgan,with respect to the weight.That is maybe why the engine in the Morgan has to deal with higher temperatures?
Rudolf.
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Stationary in town traffic Mike?
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
I can't understand why, if the motor is sufficuently cooled when cramped up in a frame with one cylinder masking the other the M3W, with the two pots open in the breeze, it needs additional cooling.... I'd say its because motor bikes are never stopped by traffic, they just create another lane
Slowly going green
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
It would be interesting to know exactly when the engines in the Morgan are overheating i.e. under what speed/load conditions. I have yet to have mine go into skip fire even in traffic in the summer. Having said that the only time I've been properly stuck in virtually stationary traffic for about half an hour it was on a slight downhill so I just shut the engine down and gently coasted. At least on a bike you don't really get stuck in traffic jams like that.
Posts: 1,213 |
I found mine would go into the skip fire mode within about 5 minutes of sitting in a queue on a hot day in the summer , so in hotter climates this must happen a lot .
The cylinders are slightly offset presumably to help when used in a bike , although it's hard to see it making much difference .
Hugh
Mines done it a few times but its never got hot enough in the UK for this to happen.
The offset of the cylinders I think is more to do with the cylinder and rod position on the crank rather than for any aerodynamic reason
Slowly going green
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Harley sell fans for their bikes too, but badge them as 'for parade use' to stop the leather tassle brigade getting scared. I've had my 'Glide drop to one cylinder but only in the snarl up chaos known as Monte Carlo..in August..in leather jeans..my, what a laugh
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
It will be interesting to see how they handle in Australia when allowed. Sitting in traffic in 40 degrees or even driving around on a 40 degree day with little breeze. I guess there wont be too much posing going on.  Not built for slow drives down the coffee strip with one arm on the door frame and the other (hopefully) on the wheel in summer
Graeme: 2011 +4
