6 members (RichardV6, Alistair, B3MOG, Carbuilder, Morganmike, JohnHarris), 216 guests, and 25 robots.
+8Rich 103
John V6 66
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,506
AlexCreasey
#171885 20/12/13 06:54 PM
DaveW Offline OP
I managed to get some time in the garage today.
First I fitted the skids to the exhaust. No real reason for this except that it tidies things up and stops the crud accumulating on the mountings.
Rear:
Front:
Next the windstop. I decided to upgrade the brackets on the Roadster with 2mm aluminium, and at the same time make some for Bumble. I used up some offcuts so the second pair are slightly smaller. It takes a while and a good deal of work to get to this stage:
Then cut the holes:
Old on the left, new on the right. I've modified the dimensions slightly.
Smaller pair for Bumble:
Adding U section neoprene edging:
Test fit:
Thankfully these brackets work with the smaller head restraints!
Completed:
Good job Dave, very neat solution.
Martin (Deano)
Very smart as ever Dave.
Dave,
A) do the seat belts run ok with this in place?
B) could you pm me the spec of the Perspex and the suppliers details please
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
DaveW Offline OP
Robbie
Yes, belts work OK.
Sourced from The Plastic Man (who else!)Same place as my spare wheel filler comes from.
http://www.theplasticman.co.uk/index.php?area=calculator
For the draft stop - Polycarbonate (unbreakable).
You spec the whole thing, including radius of corners, I also have polished edges, and spec the holes, because they drill super clean holes.
I need to dig out the measurements from the garage so I'll post them later.........
You now have a PM packed with dimensions! rtm
Received --Many thanks!
Robbie
211-WX-1433
DaveW Offline OP
Post Photobucket Re-Boot from December 2013.
Rear:
Front:
Then cut the holes:
Test fit:
Completed:
Nice work Dave
Craig Jezz
Formerly known as Aldermog
That is a great example of lateral thinking...well done!
More great work from the Wellings Catalogue!
Well done Dave - you really could start a business!
Neil
