Old Book
Topics49,940
Posts838,606
Posts: 1,338 |
Im going to have him check this number [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps12e6f7dd.jpg.html]  [/url]][/url]
Posts: 1,338 |
I just changed the bevel box oil,but it was heavy & dark [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsad4c5e8b.jpg.html]  [/url]][/url] [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps1bd7e9ef.jpg.html]  [/url]][/url]
Posts: 1,338 |
I used this oil,but it doesnt feel as heavy [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps561fffc9.jpg.html]  [/url]][/url]
Posts: 1,338 |
Its easy to drain the b box oil,but to add and to close the cap oil well,its much easier and cleaner to remove the seats,4 bolts in the back,and the you just pull the lower seats and they come off
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Did it make any difference to the noise when running?
Richard 1976 4/4 4 Seater
Posts: 1,338 |
I yet to drive it,but the new oil isn't as heavy as the factory oil,when you feel it.i changed the oil at 700km's.and i flushed the bevel box oil with some cheaper 75-140 oil..i toped the oil to the orange oil cap hole and then closed it
Posts: 1,562 |
Hi Q8
Did you get any other photos as you changed the BBox Oil ?
Cheers
Posts: 1,338 |
Nope but its very easy,bolt 24 to drain the oil under the car.then remove the storage cover.then 4 bolts for the upper seats #13..then you remove the two bottom seats,and pull the lower back seat,and then a few screws to move the metal panels to get to the b box to add the oil.All together max 1h & so
Posts: 1,338 |
Its easy to adjust the steering,my wheel was off,first cut the tie down on the rubber cover.then use a wrench 22 to unscrew the nut & a 13 wrench on the black rod to adjust the wheel in or out...now my steering wheel is center,but it still pulls to the right abit..i will use it a few time then adjust it to prefection [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsd7081952.jpg.html]  [/url]][/url]
