0 members (), 180 guests, and 74 robots.
+8Rich 76
Topics49,861
Posts837,542
Richard is correct Ian, mine's only got one bleed screw at the rear.
1972 4/4 2 Seater
On the rear, the brakes are piped in series, rather than in parallel, so the brake fluid goes into the left cylinder, out through the 'bleed' hole, then across the axle to the right cylinder. So the left side should be self-bleeding through the right side. Usually the brake line is tee'd in the middle of the axle so you would have to bleed each side individually, which is of course what you will need to do on the fronts.
Fjemog
1993 Plus 8
IanA Offline OP
:santa2:
Excellent, thank you.
1993 Plus 8 Connaught Green
Various older cars and motorcycles
Big American Bulldog
