New
Topics48,365
Posts813,374
Members9,215
Posts: 1,562 |
Combining PeterG's rubber strip and HJP'S cut down plexiglass , fit a rubber strip cut from sheet rubber the thickness of the plexi in place of the plexi in the body slots, held in by the bolts in the same way as the plexi, sticking up just enough to touch the lower side of the aero screens ? The shape would approximate to atlante's aluminium filler piece, but be about an inch taller. This would achieve the effect seen in the photo above where there is a black band below the windscreen.
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
Yes i thought to do that when i made the second side. Perhaps it is the solution
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Combining PeterG's rubber strip and HJP'S cut down plexiglass , fit a rubber strip cut from sheet rubber the thickness of the plexi in place of the plexi in the body slots, held in by the bolts in the same way as the plexi, sticking up just enough to touch the lower side of the aero screens ? The shape would approximate to atlante's aluminium filler piece, but be about an inch taller. This would achieve the effect seen in the photo above where there is a black band below the windscreen. Good idea If you can get the rubber in a thickness to fill the strip left by the removal of the plexi glass and silicon, it would make replacement in the future of the worn rubber very economical and a reasonably easy job. Now if we can get the strip in the middle filled in as well raise the height of the windscreen frames we can start on the roof
Posts: 1,790 Likes: 3
Posts: 1,790 Likes: 3 |
I had Brooklands aero screens on my last 3 wheeler and you couldn't pay me to fit them to this one. They look great but are next to useless in the wet.
Posts: 1,562 |
They are approx the same surface area as the factory ones, so assuming we can make the joint with the body watertight, how would they be any worse?
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Now if we can get the strip in the middle filled in as well raise the height of the windscreen frames we can start on the roof Something like this? 3 Wheeler with Roof
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
They are approx the same surface area as the factory ones, so assuming we can make the joint with the body watertight, how would they be any worse? I don't know how but they just are......but they do look good. I will not be fitting them either.
Sort of, but without the windows at the side just a rear window and preferably in aluminium.
However it wont be for a few years as it will effect the warranty I have been told.
Then when you start to think about I might as well get a 4 wheeler with a hard top.
Posts: 14,009 |
Now if we can get the strip in the middle filled in as well raise the height of the windscreen frames we can start on the roof Something like this? 3 Wheeler with Roof Or this?
Now if we can get the strip in the middle filled in as well raise the height of the windscreen frames we can start on the roof Something like this? 3 Wheeler with Roof Or this? Brilliant
