Topics48,362
Posts813,331
Members9,215
Posts: 986 |
Dim or what!  Hadn't thought of the phone charger. Will keep you posted when I've experimented. Andy
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
Posts: 541 |
I have an older model of Cetec and put it in the device in the glove box. It works fine and sometimes you can se the lamp switch to half and then go back to full. However it is important that you connect the plug so it is firm. If it´s not you can see the lamp blinking and the you have to turn the plug a little bit and you see the is firm again. Ken in Sweden
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Posts: 986 |
It's alive! Just tested and the 12volt socket is live with the ignition turned off.
Andy
Posts: 881 |
Very much in the dog house, could be up for rehoming
Posts: 96 |
I usually turn mine off on the cut-off; but didn't in September/October. Low and behold, dead as a dodo.
Jumped it and drove about 40 miles and stopped for fuel; turned the key; barely a click from the starter motor!
RAC diagnosed a dead cell and I'm waiting to go to Halfords for a new one.
A new battery will be nice for peace of mind. If that's all that goes wrong with the car, I'll be happy!
1994 Plus 8
Posts: 7,068 Likes: 21
Posts: 7,068 Likes: 21 |
109er, Could you tell me what model CTEK you use? I also want to connect a charger via the lighter. Thank you I use a CTEK through the cigarette lighter socket if the Mog is not driven for more than about two weeks. I do the same with my Elise, and it still has the original battery of 2006, still in good condition. Andy
Posts: 6,829 Likes: 59
Posts: 6,829 Likes: 59 |
I can vouch for the CTEK as well. It is a conditioner as well as a charger and can be left on the battery overwinter if needs be.
Posts: 681 |
OZ 4/4 - I know your query wasn't for me but, if it helps, I use a CTEK Multi XS 3600 through the under-dash 12v socket. Had it for 4 years and used it on my previous Caterham and now the Morgan. Gives good peace of mind.
Thanks BobtheTrain and St Eve, I will get on it ASAP. Thank you both for your prompt replies.
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
109er, Could you tell me what model CTEK you use? I also want to connect a charger via the lighter. Thank you I use a CTEK through the cigarette lighter socket if the Mog is not driven for more than about two weeks. I do the same with my Elise, and it still has the original battery of 2006, still in good condition. Andy Repco stock the adaptor.
Richard 1976 4/4 4 Seater
