5 members (Alistair, B3MOG, Carbuilder, Morganmike, JohnHarris), 185 guests, and 16 robots.
+8Rich 103
John V6 66
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,506
AlexCreasey
Page 1 of 6 1 2 3 4 5 6
#174752 07/01/14 03:14 PM
DaveW Offline OP
The 4/4 2 Litre gets 185/70HR15 Avons - a sticky road & track tyre - but costly to replace. So I've been idly looking at what's out there when the time comes to change (not yet by the way). The only regular hit on line is Vredenstein which I think might now be used on E Type Jags.
The obvious solution is to go for either 185/65 or 195/65HR15, but what size does the Plus 4 get as standard these days?
DaveW #174756 07/01/14 03:37 PM
Vredenstein tyres are very good, also on wet roads,but they have this issue !! which looks terrible I think scared
Almost the same problem on my "Babydoll"
DaveW #174769 07/01/14 04:35 PM
That imperfection is not going to suit you Dave! The original Conti's on my 4/4 had a similar moulding "defect".
DaveW #174771 07/01/14 04:50 PM
Dave the standard tyre size unless they have change it is 195/60HR15. The thing is that Morgan adjusts the width of the mudguards depending on what tyre width is ordered. The 195 is 10mm wider than the 185 fitted to the 4/4 2 Litre so will probably stick out a fraction, perhaps only a few mm, and be more likely to throw road grime, mud etc. outside the guards.
If you are worried about ground clearance you need to be careful too. A good site that allows you to do tyre comparisons is http://www.1010tires.com/Tools/Tire-Size-Calculator
but they no longer list the 185/70HR15. Attached is a pdf file of some information I obtained regarding changing my tyres to 195/65HR15.
DaveW #174778 07/01/14 05:40 PM
I find this tool quite useful...
http://www.miata.net/garage/tirecalc.html
DaveW #174779 07/01/14 05:47 PM
DaveW Offline OP
Thanks for the info all. My Golf had Dunlops with those moulding dents, and yes it drives me mad!
DaveW #174784 07/01/14 06:02 PM
Dave - the "moulding dents" as you call them are caused by a problem in the construction process with control of the "splice" width at the point at which components are joined. If the overlap of the component being spliced is too large it can cause a visible hollow and bulge. The area immediately behind a heavy splice stretches, spreading the gap between radial cords in the body ply of the tyre or reducing the gauge in the sidewall at that point. In extreme cases this can cause a serious weakness in the integrity of the tyre. All manufacturers should control the amount of undulation variation to prescribed limits laid down by O/E customers with a slightly looser limit for replacement tyres. Tyres exceeding these latter limits should be scrapped. Ruud's tyre photo illustrates a serious level of undulation and it would be wise to replace that tyre immediately.
Don.
DaveW #174785 07/01/14 06:13 PM
DaveW Offline OP
That's interesting Don, because all four tyres which came with my Golf - new in 2001, were like that.
PS - long gone!!!
DaveW #174794 07/01/14 07:28 PM
Dave - I took some photos of a stack of plus 4 black wire wheels at the factory in May. They were fitted with Avon 195/65x15 winter tyres.
Nigel
DaveW #174796 07/01/14 07:45 PM
Ah! That is obviously to give that extra centimetre of snow clearance smile
