Posts837,276
Most Online1,063Jun 14th, 2026
I recently checked the socket on my 2013 4/4 for the same reason and it is live with the ignition turned off. Andy
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
So a simple 12v socket solution might be live to battery with an in-line fuse and to earth.
Worked for me (albeit on a 4 wheeler but no difference in principle).
Richard 1976 4/4 4 Seater
Use the socket and be done, everything else is over complicating it.
2000 G500, UNIMOG 1550L37 DoKa, M3W
I use a CTEK unit with a fly lead permanently attached to the battery and routed into the passenger compartment - takes seconds to connect/ dis-connect and avoids the bonnet removal saga
So the Morgan battery will trickle charge the same Morgan battery?
2005 Roadster 2013 M3W MOG South
