2 members (Hamwich, TBM),
408
43
SORN
Topics48,376
Posts813,552
Members9,215
Posts: 1,947 |
In two words, weight distribution.
A battery mounted at the rear and low down is just what the doctor ordered.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
That's why twin sixes were standard on MG's up to the late 70's, but these days they all change to a single 12v, and some move them under the bonnet.
Posts: 14,723 Likes: 151
Posts: 14,723 Likes: 151 |
My Maserati had the battery in the boot (trunk for Americans) on the off side but given that it was originally a LHD car it would have been Italian near side.
Posts: 14,009 |
Certainly with the current range of cars there is no room under the bonnet for the battery! I haven't found that it gets covered in water or road dirt in the back.
Posts: 96 |
Certainly with the current range of cars there is no room under the bonnet for the battery! I haven't found that it gets covered in water or road dirt in the back. Indeed - this one has come out pretty clean! Not sure the car has ever been out in the wet though...
1994 Plus 8
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Certainly with the current range of cars there is no room under the bonnet for the battery! I haven't found that it gets covered in water or road dirt in the back. Not sure 'd like to have to drive through more than a couple of inches of water!
This is why you shouldn't drive a 3.0L Roadster through water: The flywheel is exposed at 6 o'clock on the Series 1. Maybe this was revised with the gearbox change from Getrag to Ford.  Some time ago I fitted a plate to keep the road dirt out.
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Richard 1976 4/4 4 Seater
Posts: 112 |
A bit late for this thread but www.tayna.co.uk is worth a look. Quick delivery too. No connection etc...
