0 members (), 170 guests, and 68 robots.
+8Rich 68
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,882
Posts837,806
Gyp
Page 3 of 4 1 2 3 4
Chris99 Offline OP
What a difference an inch makes wink
Fitted the 25mm spacer from Revolutions today and it makes a world of difference. I can now easily move my left leg and get my foot away from the clutch.
It also makes getting the ignition key in easier.
Red Leader drive
Originally Posted By PaulJ
Only having an inside leg of 31" I've never needed the spacer, so forgive me if this question seems a little silly, but doesn't spacing the wheel out, mean that it is then too close to the chest for easy twirling, or does it have that vintage up close feel.
I find that the 50mm spacer gives a bit more leverage without restricting movement. I have always preferred to have the wheel relatively close and for me the straight-arm stuff increases effort too much. In many cars, once I have the seat/pedal distance perfect (which is not possible in the M3W), the wheel is too much of a stretch.
Driving ergonomics are rather complex.
Neat fix!
I fitted my 25mm spacer from Revolutions today & echo Chris's comments. I can now fully get my foot of the clutch. I did not have the special tool to fit the head on the security bolt but managed with a screw driver.
Seems MMC are missing an opportunity here leaving it to dealers or DIY route to fulfil a need. Why don't they offer a range of different thickness spacers & put it on the options list or accessories?
My My. but the solutions to "long legs" never cease to amaze me. I just installed a MOMO Mod 26 steering wheel and the results were amazing (for me). The wheel is about 11.4 inches dia and cut flat on the bottom. I was worried it might be too small, but it seems not. I did a test drive yesterday and WOW what a difference for my legs AND I can actually see the speedo (LHD). I will be moving the pedal box forward shortly. Have already raised the front of the seat up about an inch.
Yes, the 11" wheel works well, I'm using a flat 11" Motolita leather wheel, but only having a 31" inside leg, I'm not troubled by my left leg and steering wheel interaction.
Revolutions have a couple of 1" spacers as yet un-coated available. The satin black powder-coated finish of those that Chris, Tim & now Valentine have compliments the standard M3W steering wheel finish just nicely.
They have been CNC machined and the program that produced them can machine them to a specified length. We're here to help!
I board made ​​a thick spacer to reduce and I started if its not covient, I took the opportunity to offset the branch of flying for her silk three hours to even my counter kmh.
http://www.hostingpics.net/viewer.php?id=971743Photo0269.jpg
http://www.hostingpics.net/viewer.php?id=870282Photo0270.jpg
http://www.hostingpics.net/viewer.php?id=596477Photo0271.jpg
Hmm. I don't follow you, not even remotely... Send that in your own language. If it's French, I'll have a go at translating it into English. If something else, I am sure someone on here will help you.
I think GLLOQ is saying he offset the wheel a quarter turn so he can see the speedometer
Page 3 of 4 1 2 3 4
