7 members (Heinz, Barry M, +8Rich, hillclimber, JohnHarris, RedThree, MJF),
221
83
Topics49,848
Posts837,403
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
Thanks Hugh and Blake!
Luckily, although the Caterham is a true lightweight, it does need motive power, otherwise Fred Flinstone and Barney Rubble would have had the right idea.
When I bought my car the previous owner had fitted the incorrect engine, and I've now sourced the correct engine, simple as that. A bit like buying a Morgan Three Wheeler with a HD engine, instead of the S&S.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Pictures would be welcome.............
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
i think an atom bomb could go off down the block from peter and he wouldn't hear it over his exhaust. Peter I've heard the exhausts on your car - do you think the soundproofing will make a big difference? Blissfully unaware of any tapping, knocking, squeaks or rattles, policewoman (person) not very happy though, I had to turn the engine off to hear her complain about the noise, she sort of believed me when I explained about the noise bouncing of the tall buildings in Southend-on-sea...  Either that or it was my dashing good looks  Once I'd removed the flying hat, face mask and goggles! PaulJ The sound proofing material seemed to reduce the temperature on the prop tunnel, although this was only tested via the touch method I couldn't find a grub screw to remove so I could insert my probe.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
So racing the Escorts on the prom Peter? White socks I assume!
Richard 1976 4/4 4 Seater
I think it's now 20 mph from the Pier to the Kursaal, normally one slow moving queue anyhow...cameras
