10 members (+8Rich, High Hamster, MartO, jbk, RubyMog95, JohnHarris, James B W, RichardV6, Peter G3VNH, sezznowt), 311 guests, and 106 robots.
+8Rich 76
Topics49,869
Posts837,664
Moggo
#179684 03/02/14 01:02 PM
Hi to all of you!
I'm loking for a clutch kit for my Mog, the clutch disk has total diameter 215-220mm, the hole has 20 spline inside, i found many clutch kits on Ebay but mostly 195mm diameter, which kit should i consider to buy?
Thank you for your help!
Ciao
Fabio
'71 Morgan 4/4 2 seater
'56 Austin Healey 100 M
'52 Jaguar XK 120 OTS
I'd contact the likes of Brands Hatch Morgan or Melvyn Rutter. They'll know for sure.
The last kit I put on mine was a Borg & Beck HK8144 if that's any use to you.
1972 4/4 2 Seater
With any Morgan of that age, there'll always be some question over the parts. Reason being, you can't rule out a previous owner renewing something and using what he had, rather that the 'right' bit.
Probably the tricky bit will be the release bearing and the fit to the driven plate. Buying plate, cover and bearing from the same place should help.
Do the existing components have part numbers that could be used for cross reference?
Just a thought.
