5 members (scortroadster, IcePack, Zach, Burgundymog, nick w), 252 guests, and 92 robots.
Topics49,847
Posts837,389
Page 6 of 8 1 2 3 4 5 6 7 8
Another view.
SBM Offline
Originally Posted By Dab of oppo
The hole I cut in the bottom is like a teddy bears head upside down, and then cut 2 angles so it would fit snugly between the trans. tunnel and dash trim.
I then made a hidden clamp to hold it in place so no holes had to be drilled in the trim.
Mate, that's hilarious..!! Poor Pooh grin2
I will be installing a Formotion Clock and Thermometer, they were fairly reasonable.
http://www.formotionproducts.com/C&TMAIN.htm
http://www.formotionproducts.com/SB%20Accessories.htm
You'd want the Snap Back line, with the black mount. I think I spent $35 each on the clock and thermometer and $15 for the mounts. You then just either glue or double-sided tape them where you want in the Morgan. I would like to re-do all the gauges in general, but that's a project for down the road.
Those are rather neat Tide! If I hadn't fitted a MIG clock in my four wheeler I'd have been very temped with those.
The MIG "teddy bear" shape makes cutting into a dashboard a very time consuming task....no room for error whatsoever!
Dab
That looks great. Is the chrono internally illuminated?
Tim.
There is no provision for illumination on the clock but the green bits really do stand out in the dark.
I think my "radioactivity" has worn out on my MIG clocks! I fitted a small light post by the side of the clock to illuminate it.
Dab...that is a really smart looking install of the MIG clock - BRAVO!
I was thinking about fashining a plywood box and covering it in leather to achieve a similar effect.
But I realized that I'd probably never reset or wind the darn thing, and thus abandoned the idea...
Nice job!
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
Toys for Boys
Toys for Boys
First fix of the Adriatica clock and chronograph. I had a piece of aluminium plate kicking around, so with a bit of bending and 2 x 40mm pipe clips it attaches to frame of the centre console. I'll probably refine it a bit once I find a piece of engine turned material to match the dash but quite pleased with the result.
Omne trium perfectum
Nice work. I have just received my Adriatica clock - was going to mount it on the main dash on the passenger side where you have the engine turned replacement pieces , but not sure now .... smile
Are the bolts holding the clocks in place dummies ?
